ik zou deze fiets willen kopen uitgerust met een LX groep, is er veel verschil met de XT groep ??
Model Traveller (G)
Segment Trekking
Seizoen 2009
Framematen 50-54-57-60-63-66cm
Frameomschrijving Completely hand-built Super Smooth TIG-welded frame. Tubes manufactured in triple-hardened and oval oversized triple-butted 7005 aluminium. Down tube with integrated shifter cables. Equipped with integrated headset, basements for all accessories, integrated kickstand, disc brake connection in rear-end, and a replaceable rear derailleur hanger.
Voorvork Chromo-Alloy
Balhoofdstel Tange Seiki industrial bearing - Integrated in frame
Kleur Grey metallic///
B.P.C. Yes
Stuur Koga Multigrip - Ergonomic multiposition handlebar - Black color
Voorbouw ITM Trekking alloy - adjustable - quill ø25,4 - Black color
Grips Koga Genuine Leather Multigrip
Rem (voor) Shimano LX V-rimbrake
Rem (achter) Shimano LX V-rimbrake
Schakelgreep (r) Shimano Deore LX rapid fire plus - Two way release - Optical gear display
Schakelgreep (l) Shimano Deore LX rapid fire plus - Two way release - Optical gear display
Remgreep (r) Shimano LX
Remgreep (l) Shimano LX
Remkabels Stainless steel inner cable -Flexible outer cable with teflon tube for light braking
Derailleur-/Remkabels Stainless steel inner cable -Flexible outer cable with teflon tube for light shifting
Ketting Shimano Deore LX Hyperglide for smooth shifting and riding
Voornaaf Shimano DH-3N71 6V/3,0W - Lightweight sporthub - Low rotating friction - Quick Release
Achternaaf Shimano Deore LX - Double contact sealing for low maintenance and increased service life
Banden Schwalbe Marathon 37mm - Kevlar Guard and S-skin side protection - Side reflection
Binnenbanden Continental 28/47-622 - 42mm valve
Velgen Koga KM21-622 XStrong alloy - Double wall and double eyeletted 36 holes - Durable finished - Black color
Velglint Hermanns innertube protective
Spaken Sapim stainless - Cold forged reinforced
Zadel Selle Italia FLX Man - Genuine full grain leather
Zadelpen Satori alloy - Safety Clamp construction - Black color
Zitbuisklem Koga alloy
Crankset Shimano special Deore with alloy middle chainring Hollowtech II - UltraLightweight - Hyperdrive chainrings for smooth and precise shifting: 48x36x26T - Silver color
Pedalen Koga VP-191 alloy - Industrial bearing - Anti slip layer
Cassette Shimano Deore LX HG-80 9 speed - Hyperglide for quick and smooth shifting - Sprockets: 11-12-14-16-18-21-24-28-32T
Achterderailleur Shimano Deore LX
Voorderailleur Shimano Deore LX
Derailleurbeschermer Koga stainless steel
Pomp Koga Telescopic with alloy barrel - Schrader and Presta fit - High Pressure/ Big Volume switch - Ergonomic hinge grip
Bidon Koga alloy 2x - Hygienic innerlayer - Easy refill - Silver color
Bidonhouder Elite Taki 2x
Bel Widek Decibel II with compass - Black color
Spatbord (voor) SKS P-45 - Black/Silver color
Spatbord (achter) SKS P-50 - Integrated rear light wiring - Black/Silver color
Koplamp Koga Rayo Senso - New IQ-LED technology 32 Lux - Integrated reflector - Standlight function - KBA approved -Black color
Achterlicht B&M 4DToplight multi senso - Long life LED technology - Battery and Dynamo mode - KBA approved - Black color
Dynamo Hub
Achterdrager Tubus Logo - Steel tubing max 40 kg - High/Low bag position - Durable black powdercoated finish - 10 years guarantee
Lowrider Tubus Ergo - Steel tubing max 15 kg - Durable black powdercoated finish - 10 years guarantee
Snelbinder Widek Triobinder T - Black color
Standaard Pletscher Comp - Superb stability - Powdercoated durable finish - Black color
Slot AXA Defender RL - ART ** aproved - Folding key - Black color
Zadeltas Koga Medium with click fix system
Speed 27
Gewicht 16.6
Model Traveller (G)
Segment Trekking
Seizoen 2009
B.P.C. Yes
Dynamo Hub
Speed 27
Gewicht 16.6
