h2gilks123 schreef: ↑wo 07 sep, 2022 10:10
Ideally around 1,000 euros for everything but I can happily spend less or more if needed
Sounds like a healthy budget for a used bike. Watch out for buying a moneypit because it needs a lot of parts changed due to expensive damages or a lack of maintenance.
Route: Via Francigene, starting north of Turin and ending in Rome, plan to go in October (hoping the weather is not awful!!). I get the sense that the road is a mix of everything, asphalt, gravel tracks, some dirt roads.
With a lot of luggage and travelling also on gravel and dirt tracks you'll benefit from wide tyres. 26 inch/559 wheels will give you this possibility. With 28/29 inch/622 wheels the more recent or mountainbike origin bikes will also do, while most older and more racing bike origin bikes won't be able because frame and/or fork are not made for fitting wide tyres.
Frame: I was thinking steel as my understanding is that it is the most durable. What are your thoughts on this?
A good steel frame will do the job, a good aluminium frame will also do. Sometimes a manufacturer combines materials in for example a steel fork with an aluminium frame.
Other bike parts: No preference on handle bars due to experience and on the other questions, I don't have a lot of experience but i would think derailleur and chain drive for ease of repairs.
With your budget derailleurs sure are the best choice. Regarding handle bars, trying out can help you find your personal preferences. Changing between different flatbars or different dropbars is cheap most of the time, while changing from flatbar to dropbars or from dropbars to flatbar mostly isn't.
Commuting: I don't think I would use the bike for commuting as I have a day to day bike and currently live 5 minutes from my office but i would definitely take weekend trips to explore this wonderful country
Good choice splitting this up, that'll reduce the risk of your nice touring bike getting stolen and needing a lot more maintenance in Dutch winter weather.
h2gilks123 schreef: ↑wo 07 sep, 2022 09:06
Do you also have any suggestion of good makes to look for? It seems there is a lot of Koga which would make sense as a Dutch company. I am looking for something robust for a 3-4 weeks journey.
Some Koga models will be perfectly capable for your trip, while others totally won't be. Look for example for a WorldTraveller, forget about the WorldTraveller-s, as these were complicated older full suspension models.
Also popular in the Netherlands are Santos bikes. Most models are also capable for a month trip with a lot of luggage, except for some fancy carbon fiber or racing specific ones.
Giant also did a good job on some model years of the Expedition, while other years of the same called model were... just not so good for travelling.
In steel you can also look at the German brand of VSF, just skip the cheap ones with Shimano internal geared hubs. Those are good commuter bikes though. Also in steel you can look for example for the Dutch brand of Avaghon or the USA origin Surly, but those are a bit more expensive most of the time.
Starting with a mountainbike without racks can also be a good start for creating your own touring bike, just make sure you'll have a good base strong enough for touring, carrying all your luggage and racks. A light and race winner designed bike most likely won't be capable
The more you will get your luggage down in weight and volume, more bikes will be suitable for this and future trips.
And as for the 60/61 size stated in the title. That can sure be the correct size for one frame from one specific brand and model, while due to geometry differences another frame can be a perfect fit for you in a 49cm size. What's your length? And what about the inner length of your legs?
