Wechsel 2 persoons trekkerstent Intrepid 2, Zero-G Line Sand, 3 kg inc. footprint; zgan!
Omschrijving en specs:
Mooie ruimte-efficiente en lichte trekkerstent.
A-merk kwaliteit, zeer slimme details en doordachte uitvoering.
Inclusief bijpasende footprint (Wechsel)
Zo goed als nieuw. Weinig gebruikt.
Gaat weg wegens familiegroei (een grotere tent nodig)
Size Innertent (LxBxH): 220 x 125 x 98
Apsides: 1
Doors: 2
Delivered Weight: 3.04 Kg
Packsize: 50 X 19
Flysheet: Ripstop Nylon 40D 240T, both sides Silicone coated, 2000mm, 53g/m², tearing resistance 11kg
Inner tent: Ripstop Nylon 30D 280T, WR, 38g/m²
Floor: Nylon Tafetta 70D 210T, PU 7000mm, 110g/m²
Moskquitonet: Nylon Noseeum 40D
Tentpoles: Aluminum 7001 / Scandium
Tentpegs: Dur-Alu Peg
Footprint/Groundsheet: Nylon Tafetta 70D 210T, PU 5000mm, 110g/m²
The Intrepid 2 is a 2-person tent with large rain-protected entrances and one vestibule. The three flat channels for the poles simplify set-up and cause less wind-resistance, making the tent quieter as well. The special steep shape of the vestibule lets you sit comfortably under it and use the entire space. The inner tent can hung in after the tent is set up and removed in part or completely as desired. A large and completely coverable mosquito net door is integrated on the D-shaped inner tent entrance. Inner tent pockets and a gear loft made from mosquito netting allow quick access to small items. The vestibule has a side entrance and a front entrance that can be rolled up, which offers excellent protection from the elements when the side door is closed. The closable vents on the inner tent, as well as three apex vents on the fly allow for optimal ventilation. The tent is very aerodynamic and thus very stable. The Intrepid 2 is a lightweight tent while still providing comfortable quarters.
Apsides: 1
Doors: 2
Packsize: 50 X 19
