Hi All,
I couldn't find a section on the forum for consumer advice or tips. I have the below problem and hope someone can help give some consumer advice on bike repair shop problem.
Myself and my partner are Ex-pats living in Leiden. My partner uses her bike to get to work but had an intermittent problem with the back wheel losing drive. I tested it and since the gears were working ok, I read it was most likely the cassette inside the back wheel.
I tried to fix it with by warming the grease and using WD40 since internet advice was that sometimes they get clogged inside, and that if that didn't work we needed to get a new wheel (€20-30?).
Later it happened again so she took it to the bike shop next to Leiden Centraal. Her bike cost €170 second hand and other than the back wheel problem was in ok condition. When she picked it up after leaving it with them, they had replaced the whole chain system, derailleur and cogs, (which were working fine) and charged €70.
When she said they had not fixed it, and they shouldn't have changed the chain system, they told her, "that's what they always try first", but they now tested it and know what the problem is. They said they didn't try it first because it's more expensive. However this makes no sense, since they say the additional cost would be 40. So they tried the more expensive thing first without testing what needed to be fixed.
She took the bike but the problem is still happening and now they want another €40 to continue to fix it. I think replace the wheel like they should have done straight away.
This would put the repairs to 2/3 the price of the whole bike. Personally I would like them to put the old chain system back on and refund the money, or minimum to finish the job they were given at no extra cost. It feels like the shop has either done extra work because my partner didn't know about bikes, or they are incompetent and started unnecessary work without testing what needed to be done.
From what I have read the whole repair should have been for new wheel + fitting.
She already paid €70 and has the bike back but it still has the same problem and also she says the new gears don't change as well as before, so they have actually made it worse. If she pays again it will be €110.
What do you do in this situation?
Thanks,
Mike
[moderator]Moved to appropiate forum [/moderator]
Thanks,
Mike
