Additionally, paste this code immediately after the opening tag: Surly Troll - Forum Wereldfietser
Surly Troll
Ik verkoop een zo goed als nieuw Surly Troll kader.
Het is een 18", kleur: Egg Plant
Nog geen 200 kilometer mee gereden maar het kader is me net iets te klein, heb dus maar een 20" besteld.
groeten,
Fre
Fret schreef:Hoi,
groeten,
Fre
To Whom It May Concern
http://surlybikes.com/bikes/troll
Though the Troll’s geometry is that of a 26˝-wheeled mountain bike, it’s unlike most mountain bikes you’ll find on your local bike shop floor. It has ample clearance for 28/38/50t mountain-triple chainrings and room for
26 x 2.7˝ tires. The gusseted front triangle, with its sloping toptube, provides generous standover clearance even when running high-volume rubber.
Build it with a 100mm suspension-corrected fork, or roll the 4130 CroMoly Troll fork. The stock fork is spec’d with canti pivots, disc mounts, low- and mid-blade rack bosses and fender eyelets. Run a rack fender and disc at the same time, no jury-rigging required.
The Troll frame features horizontal rear-loading dropouts with a derailleur hanger, disc caliper mounting slots, and rack and fender bosses. There’s a dedicated area for anchoring a Rohloff hub OEM2 axle plate, and we’ve included threaded M10 x 1mm holes for installing Surly trailer-mounting nuts or B.O.B. Nutz. The dropout design allows the simultaneous use of a rack, fender and disc brake. We include canti pivots, too. Options, options, options. Marcia, Marcia, Marcia.
Use the Troll as a mountain bike, cruiser, commuter or touring rig. Make it your go-to utility tractor. Try out different tires and handlebars. Add some racks, build it with gears, or strip it down to a singlespeed drivetrain. Take it camping, ride it to the grocery store or session on your favorite single-track. Build it up, ride it for a while, then reinvent it.
Like many of our models, the Troll is available as a frameset
or as a complete bike.
Wat mag dat moois gaan kosten ??
Gr Leo
Voor 360 euro mag het kader weg.
hoe groot ben jij
Mario
Ik ben 1,82m. ,
lengte was voor mij geen probleem, rij zelf met korte stuurpen en hou van een compacte houding op mijn fiets maar ik heb een lange binnenbeenlengte waardoor het zadel nogal hoog moet.
